- Jun 28, 2012
You are waisting your time on this front, which is why I didnt even bother asking anyone about it. This was never about motherboards.
And you're wasting enough money to have bought another 7970.
What will the PLX chip actually gain you, in FPS, versus the native 5930K setup? More lanes... ok. Got it. But you know that a PLX chip adds latency, correct? That latency will essentially be a net wash versus native lanes at a lesser speed. So yippee you have more lanes but to what end? It literally yields you nothing except to be able to say the statement, "I have 64 lanes". That is literally all there is to it. No performance gains, and perhaps it is less due to the latency (look).The Asus X99-E WS has 64 PCI-E Lanes to work with, NO OTHER motherboard can boast that. I am running 3x 7970, and yes, if i find yet another one used, im going quad! I dont care about the only 2% difference, Gen3 16x on all 3 or 4 cards, is my aim.
Pierre, I hear ya... these are my questions in return...
Link - http://www.plxtech.com/files/pdf/technical/expresslane/Overcoming_PCIe_Latency_PLX.pdf
Link2 - http://www.anandtech.com/show/6170/...x-8747-featuring-gigabyte-asrock-ecs-and-evga
So while you are thinking you are getting the max from your hardware by using a PLX, it is actually no different or worse due to the latency it adds. Clearly its still up to you as to what you want and what you will get. Our job is to educate and inform, its yours to pull the trigger. Just don't get caught up in buying things for the wrong reasons.
Still not looking at more than a 3% difference from PCIe 3.0 x8 to PCIe 3.0 x16
Well, I'd rather do what I did, pay $299 for the CPU and $219 for the motherboard ($518 total)!Why pay $530 for a motherboard and $390 for a CPU ($920 total) when a $250 motherboard and $590 CPU ($840 total) will do the same job?
Then you have a better binned chip.
I can only assume this, but looking PLX website, that this is the chip: PEX 8764.
Reading the product info on that, its 16x/16x, with a maximum of 150ns of latency.
What does the future of PLX have to do with your current purchase? I would imagine you are correct that like the previous generation of PLX and NF200 latencies will reduce. But you are buying the current gen so the future doesn't matter much in this case.I can only assume this, but looking PLX website, that this is the chip: PEX 8764.
Another jet black mobo $230 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813130796&cm_re=MSI_X99-_-13-130-796-_-Product
As far as % loss of PLX vs native 8x, they are the same really (which is why we are having this conversation - trying to inform you of this piece, again).
Im not talking the future of PLX chips, im talking right now.
And i said NON MSI, i hate MSI boards, the Z77 Mpower took care of that.
