- Sep 8, 2011
- Las Pinas, Philippines
i was a 64 bit windows7 user just recently and had to change it to 32 bit in an unfortunate event... are there any difference when it comes to performance in gaming and benchmarking between the two?
There is no other difference other than 64 Bit allows for use of 4GB+ of RAM whereas 32-Bit uses over 3GB but less than 4 GB of RAM max. In your case the difference was negligible.
Do you use any game or application capable of using 4 GB of RAM? Most of us don't.
i havent tested it and i already reverted back to 64 bit.. i think its for the best right?
I can understand that as I also tried XP and Vista x64, XP was terrible and I don't know if it was just Vista or it was because it was x64 but I couldn't abide it at all. I originally had the 32 bit installed but changed it over to 64 when ram got so cheap I couldn't resist since the key would work either way. I can't recall having any problems at all because of it being x64, in fact if you ever need to reinstall I suggest that you try 7x64.Windows 7/XP/Vista triple boot here. Can't wait for Windows 8 final to be released to test all this because I'll finally go 64-Bit, but only with Windows 8.
As i see it - the argument that should be made more frequently in favor of 64-Bit is advantages in multi-tasking. I expect to see advances there.
Working with huge graphics files frequently *and* using 64-Bit versions of identical software would yield the advantages you're talking about. I made the decision to stay with 32-Bit because for the past three years, I am certain I had less headaches with compatibility issues using 32-Bit than I would have had if I had gone 64-Bit since 2008-present.
I figured the rig would have been updated by the time Windows 8 came out so I could go 64-Bit then.
