- Jul 20, 2004
- Schuylkill County Pennsylvania
Hello, I recently made a cooler for my 6600GT AGP card and figured that I would pass it along. The modification is both simple, quick, and very inexpensive.
I was tired of a lack of aftermarket coolers for the 6600GT. The stock heat sink and fan that I have is very loud and it doesn’t cool very well. My idle temperatures were 53C and under a load the temperature would approach 80C. Since I usually purchase aftermarket coolers for the GPU and CPU, I’ve a box full of stock heat sinks and all the mounting hardware.
I fished through the box containing my parts and found a stock socket 478 heat sink and fan for a 2.4C/800FSB/512Kb Northwood. I also found a lot of mounting hardware for aftermarket Zalman, Artic Cooling, and Thermaltake coolers. I placed the socket 478 cooler on the card and marked onehole at each end of the heat sink. I then drilled and tapped them for fine thread screws that fit through the video card's stock holes. Since the 6600GT’s mounting holes are places very far apart, I had to **** the heat sink slightly to match the holes.
The fan for the socket 478 cooler is both larger than the 6600GT's stock one and much more quiet. When run on low, the stock fan for this heat sink is very quiet and uses a standard 3 pin connecter. Even when running the fan on 8 volts, the GPU of the 6600GT was unable to saturate the 478 cooler with heat. Back to being quiet, when this is running on low, I can barely hear it. The only potential drawback I can see for some of you is that it will take up three PCI slots.
A backing plate must be used to prevent the card from flexing. I used a backing plate from a Zalman CPU cooler. It’s large enough and doesn’t conduct electricity. It also has a square opening that doesn’t cover the GPU’s electrical connections on the back of the card. I then used an aluminum bar over the backing plate. This way the screws can be tightened very hard without worry of flexing the board. Due to the 6600GT’s unusually odd mounting holes, one on each end directly down the centerline of the GPU, I felt it was necessary to make sure it was tight.
I used UBI’s Pacific Fighters for a benchmark. Don’t be fooled by this game, it’s very demanding on the Video card. While running “Perfect Mode,” water 3, and 4x AA & AF filtering, it taxes the video card more than any of the Battle Field 2 games, including Battle Field 2142. This older game in fact heats up my 6800GT and 7800GT far more than any other game I have. Using a map in the middle of the ocean with ships and the like really causes stress on video cards. The water must be very hard to render.
The results:
53C idle 75/80C load with stock cooling
38C idle 49/50C load with 478 cooler
This is my first modification and it didn’t cost me a thing. I had all the parts in the garage. Final thoughts, I almost threw away my “junk box” a month ago. I’m glad I didn’t. Nobody, past or present, makes a cooler that will fit the 6600GT that I’m aware of. Perhaps the Zalman VF700 will fit, but it’s some 30.00 with shipping and I couldn’t see spending the money for the 6600GT that’s obviously aging and being used in a 3rd computer. This modification should work for any GPU.
Best regards, bolillo_loco
The results:
