For those using v7, a new version is available, 7.1.33. THe most notable difference is the ability to install both smp and gpu slots automatically during the initial install.
Here are the change logs:
v7.1.25:
Hide 'Quit on window close' option in OSX.
Fixed some problems with WU assign time and time offset calculations.
Detect and ignore invalid assign time from older WS.
Log computed WS time offset.
Removed warning from Slot configuration about changing threads mid-run.
Catch and log error accessing battery info in /sys on Linux
Fix grayed out name and IP in client add after viewing local client. #640.
Remove 'RS480 PCI-X Root Port' from GPU whitelist. #635
Added a few new Radeon HD 6xxx cards.
Added Nvidia GTX 590 device ID 0x1088 to whitelist.
Increase Radeon HD 5xxxx and 6xxxx GPU type level by one. #653.
Don't fail WS connections if all data was recieved even on net error.
Print IP Address with 'Uploading' message.
Fixes for OSX minimize and quit bugs. #649 & #659.
Limit max CPUs per slot to system count. #652.
Attempt to fix #654.
Release system resources when querying OSX battery status. #650.
Don't send 'auth' command from FAHControl if empty. #658.
Fixed 'slot-add' NULL pointer exception. #666.
Fixed 'log-updates start' error. #671.
Fixed FAHClient script parsing bug. #676.
Show 'Remote Access' tab in advanced mode. #648.
Don't allow minimizing to sys-tray if it is not there. #670.
Also print core return code numbers in hex. #677.
Print times in ISO 8601 format. #664.
Expire WUs in sending status.
v7.1.26:
Correctly report client version to WS with WU return.
Failed upload attempt could cause WU to dump before it was expired. #679.
Added AMD Radeon HD 6600 Series to GPU white-list.
Fix failure to restart FAHControl in OSX when 'start minimized'. #649.
Fixed a socket bug that could cause the loss of the end of a message.
Build OSX client in 32-bit mode with Intel compiler.
Reduced socket send buffer size to 32KiB to try to solve #682.
Attempt to fix PCI detect crash in Windows. #695.
Whitelisted more GPUs.
v7.1.27:
Check shared info modification time in an attempt to fix #688.
More GPU whitelisting.
Fixed Windows PCI/GPU detection, broke in v7.1.26. #701.
Use WS UTC WU assign time in client wo/ computing offset #697, #681.
If running WU is dumped shutdown the core. #700.
v7.1.28:
Hopefully finally fixed the OSX on battery detection code.
More GPU whitelist changes.
v7.1.29:
Print UNSUPPORTED in front of unsupported GPUs in info.
Removed unsupported gpu-vendor-id and gpu-device-id options.
Allow auto-configuring both GPU and SMP. #629
Configure GPU & SMP by default in Windows.
Repaired OS description printing in info.
Use OS bits to determine 32 vs 64 rather than build bits. #703
Enabled GPU detection in OSX.
Removed 'gpu-id' and added 'cuda-index' and 'opencl-index' options.
GTX465 -> Fermi. #661
Automatically install themes in Windows installer.
v7.1.30:
Attempt to fix OSX PCI scan crash.
v7.1.31:
Another attempt to fix OSX PCI scan crash.
v7.1.32:
Added 'gpu-usage' option with default of 80%.
Added percent GPU usage slider in FAHControl.
Added 'opencl-index' and 'cuda-index' options to FAHControl.
'gpu-id' -> 'gpu-index' in FAHControl.
v7.1.33:
Set default 'gpu-usage' to 100%, until GPU cores implement better throttle.
Fixed client connection rate limiting.
Fixed error reporting for bad slot configuration. #582.
Attempt to fix EUE reporting for WSv4. #615.
Fixed "Wrong architecture" bug on 32-bit Ubunut. #599.
Dropped "64-bit" Windows release. Use 32-bit on all systems.
v7.1.25:
v7.1.26:
v7.1.27:
v7.1.28:
v7.1.29:
v7.1.30:
v7.1.31:
v7.1.32:
v7.1.33:
