Well, it's not dead yet!
Modified CT-479
5/8" Aluminum U-channel I'm gonna use to mount my waterblock, along with some 6-32 3" rods.
How the U-channel is suposed to work.
Whew! Almost made a boo-boo, I had to cut out some of the channel so that the Storm would fit.
Mocking everything up, fts great! Also put in some anti core crushing cushion and my temp. probe.
A fully volt-modded 7800GS. Left to right, Vcore, VDDR, and VDDQ, along with accessible read points. The jumper is to turn them all off.
Everything inside the case, first time it's been fully closed in a long, long time!
Benches, etc.
Fastest SPI at 27.026 seconds. I could probably get better SPI time if I had 4 x 512 low latency DDR-500, but that's quite alright, no more money into this AGP rig!
This Dothan Sonoma is AWESOME! Right now I'm at 2.8GHz, it can probably hit 3GHz, except for the fact that I am maxed out on voltage. I was going to do the Vcore on the P4C800-EDLX, but I grabbed a 50ohm resister instead of a
50kohm resistor.... that would have been BAD.
As far as stability goes... not enough. Although it will run benchmarks just fine, they aren't everything. I'd take real life perforamance over benches anyday. The GS will run benches all day at 500/1700, no artifacts. But for reliable BF2 and WoW (2+ hours w/o crashing), I have to bring it down to 470/1500... Stock is 430/1300...
But overall I'm really ecstatic with the results of the entire project as it stands right now. My water temps are great! The Sonoma hasn't seen load temps above 32°C (Ambient @ 23°C)!!! The 3.2 used to IDLE higher than that! And for real game performance, I saw ~50% increase in WoW FPS in Orgrimmar! Usually during peak times it gets as low as 17FPS, averaging at 22. With the Sonoma installed the lowest I saw was 24FPS averaging at 36FPS.
