- Feb 2, 2006
- Valparaiso, Indiana, USA
Ive owned a 7800gt for almost a year now usually running 35C idle 65 full load, and suddenly its running hot, 55-60C on idle and 85-100C on load, i know it ran much cooler then this and dont know why its running so hot, i had a 500w psu, running the card for 8 months or so then overheating started. Upgraded to a Rosewell 550w psu that had very good reviews and resaults still the same, the heat is the same. After a couple hours of gameplay i get artifacts, prior to that its fine. My current system is MSI K9VGM-V movo, 2gigs ddr2 800 g-skill ram, 7800gt 256mb evga gpu, amd 4600+ X2 winsor core cpu. Rosewell RP550-2 psu. I have good air flow throughout the case (air cooling) with 7 system fans. I dont think adding another fan will help the cause.
Anyone can tell me why suddenly its running hot and ideals on how i can fix this. Any help would be appreciated. tyvm in advance.
Kevin
Kevin
