7900gs water cooling gon bad
core2due
USA-ct
My little water cooler for my vid card started to beep because the water was low so i kicked it onto it's side and it stoped beeping and i thought it was still pumping water.But it really wasn't it got so hot that after 15min that my screen whent black I heard a pop and water started to leak out of the block and steam was coming out the back of my pc. It didn't ruin the vid card I thought it would have. It is vmoded to 1.55v so it got crazzy hot.:attn:
no..... this is what you get for doing exactly the opposite of what we told you to do and buying a cheap kit :p Ive had my video card watercooled for the last 3 years and havent had a problem yet. hell, im running the same tubing and hoseclamps with coolant for the last 14 months =O.
you are very very lucky man. you had a zalman didnt you? slap that puppy on there and drop her to 1.4v. there isnt much different from 650 - 720 anyway =0
No i never had a zalmem.The water cooler works good i was just to lazy to fill it up.The only bad thing about it was it evaporates water over time.It would of died but i was only on the internet.That would of ben the second 7900gs and that would relly suck.:eek:
