- Feb 10, 2006
- Austin, TX
What are the normal temps of an idle 7900GT card? I am running idle about 46 degrees Celsius. Does that seem high? Under load, it is about 60C.
WonderingSoul said:eesh! Does your case have adequate airflow for your card? I remember my stock 7900GT KO only hitting 55c or so load in the summer, idling around 45c. I know you can get a Arctic Silencer 5 for the 7900GT and just cut off some of the end ducting to suit your card.
RocketChild said:Yeah, I get decent air flow...could always be better. Just was wondering because it looks like the GPU is going bad and I was wondering if it was over heating. I am not doing any OCing on it. When I am in BF, I jump out and my load temp is 55C, but I get strange render issues.
Now, I had heard that with the first release of the 7900GTs, EVGA was recalling/replacing the fans because they under-compensated with the new core size vs. heat. And I think I got one of the first batch.
But if those temps are fine, 46 idle & 55 load, then it might be something else.
bmx said:i have a 7900gt KO oced to 650/1600, it sits idle (2d mode 420/1320) at around 38 C, and full load it hits 65 sometimes. I have a vf900 on it too though
Thats fine.RocketChild said:What are the normal temps of an idle 7900GT card? I am running idle about 46 degrees Celsius. Does that seem high? Under load, it is about 60C.
atm743 said:how is that vf900 ???
i may get one
i may get one
{DvT}J.D.M_eg6 said:when i boughtthe card the specs said it was clocked @ 470-1350 but when i overclocked it it was 470-650 andi clocked it to 570-822 using coolbits i think(guru3d) why is my max mem clock going till 822 only.is there a way to take this higher..?
