There is a section for "core" temps in HWMonitor. There is really only one core temp sensor on the processor die but the reading is repeated several times according to the number of cores the processor has because the software is setup to also work with Intel CPUs that have multiple core temps sensors. The temp reporting varies about 1c between the several lines because of a time interval and fluctuations in temp during the time interval.
Found above the core temp section, the CPU (socket) temp may be labeled "CPU temp" or it may be disguised by a generic label "TMPINx" of which there may be several because on most motherboards there are sensors in various places. It can be a challenge to figure out which one of those lines is the CPU socket temp but with a Thuban core processor the CPU socket temp is usually about 15c higher than the core temp when a good aftermarket air cooler is employed.
