- Jan 27, 2011
- Beautiful Sunny Winfield
I had this setup working with the parts just sitting on a desktop (and using a jumper wire to power on. ) I had shut it down weeks ago but decided to get it all packaged in a proper case and bring it up again. It's the only GPU I can get to fold. so far. When I powered it up, it no longer recognizes the GPU.
While it was down, the CMOS battery gave up the ghost. I've replaced that and gone through numerous cycles of resetting the CMOS with the jumper, using default values and changing settings manually. The one I zero in on is "Primary Graphic's Adapter" under "Advanced BIOS Features" . This has choices of Internal, PCI or PCI-E. It defaults to PCI-E. I've tried all settings and under all, the built in chipset video remains enabled and the GTX-460 is not visible to the OS. (OS is Linux, btw.)
All of this worked before I packaged it up (and lost CMOS contents.) There are no other cards installed, just a laptop HDD attached to #1 SATA port, one processor fan and now one case fan.
Any suggestions on what else to try are very welcome. Unfortunately I do not have another system on which I can easily try the GPU. Rather than rip up my main system (which I just repackaged a couple days ago) I'd just let this system sit idle (off.) With the old AMD Phenom it's not much of a cruncher.
Thanks!
