Rgone, what would be your recommendation? At this time a new cooler is not an option. I had read the reviews and there was many more positive responses than negative ("this cooler lowered my idle 20 degrees C IDLE! quite an improvement over the stock cooler. At load, it decreased the peak temperature by 18 degrees C. WOW, that's impressive!! This cooler has allowed me overclocking headroom and I won't worry about my RAM overheating because it blows directly onto the sticks." example)
I am also thinking of adding 1 or 2 more 120 mm fans located directly next to the cpu. Should I have these as exhaust or intake? Do you think with the addition of the extra fans the cooler will be adequate?
