So I have this nifty Q9650 CPU, and I'd like to overclock it. First, the specs on the rig! This would be my first real rig to overclock in any serious aspect (enabling SLI ready ram doesn't really seem to count )
Mobo: eVGA nForce 680i mobo (122 CK NF 68 A1)
Cpu: Q9650 cooled with CNPS9700 (Zalman HSF)
RAM: 8GB (4x 2GB sticks) of Crucial Ballistix DDR2 800 "rated" 4-4-4-12 @ 800 freq by the manufacture specs (BL25664AA80A)
Video Card:eVGA GeForce GTX 280 SSC Edition (01G P3 1284 AR)
PSU: Decathlon Series DA750 PSU 750W by SilverStone
Hard Drive: Barracuda 7200 x2 in RAID 0
OS: Windows Vista 64bit
Case: Antec 900
Alrighty...
I've read... ALOT... I've "played" with raising my FSB somewhat but there is much to learn and I may have missed a few things here or there. I have a few questions that I think would do well to just be asked (searching has been fruitless thus far)
First off, my CPU is a Yorkfield and I believe I've read that 1.25v is set for this cpu; so in this situation what effect, if any, does changing that setting in the bios have? Does it not actually take effect? Does the extra voltage just not get used and only create heat, wear, and tear? Can I lower the setting, assuming the rig will stay stable with a lower cpu voltage, to achieve a more efficient machine? Does this apply to both the CPU core and FSB voltage?
Second, it would seem from searching the forums there is a lot of potential in this CPU. What can I expect without really pushing the setup to the edge or without going water cooled or another "air" alternative (I would really like to do that though... someday...)
Thirdly the question that is really bugging me, even after dissecting the cpu / ram forums: delving a bit into the ram but still cpu related, is there some magic FSB / ram ratio? 1066 OC'd ram frequency is mentioned a lot in various posts. Now I believe I have a firm grasp on the somewhat complicated relationship the FSB has with the rest of the setup, especially RAM. So, given a bios (or at least mine) gives only so many ratio options, only certain FSB / Core Multiplier settings are going to give me 1066 / 800 ram freq. I understand in an "ideal" world 1:1 would be best, providing no "lag" between the ram and the FSB, but ram just doesn't go that fast, so is there a more stable ratio(s) that I should be working with? Always shoot for a FSB / Multiplier / Ratio combo that gives 1066 or 800 RAM freq? I can just "unlink" the two in my bios but that seems to give strange ratios and seems pretty unstable when I try to boot with certain numbers (even low ones, lower than I have right now) Or can I just raise one (RAM freq or FSB) to its limit, reset, raise the other to test its limits, and to hell with any certain ratio? I have other RAM questions, but I'll move onto that forum in a bit.
Finally, anything anybody knows from experience with dealing with any my components or combination of them that might be helpful... or ominous?
Thank you all for the wonderful resources, and thank for any input you may have. I am off to the RAM forums and then to get a bit more shut eye while Prime95 takes the rig for a spin...
Case: Antec 900
Alrighty...
