- Oct 29, 2012
Well, I'm a long time envelop-pushing chip-torturing Oc junkie from another overclocking community-- I'm looking to make a home here too! Right now I'm running a C2 Phenom II at 3.85Ghz (4.0 is basically chernobyl waiting to happen, even on my H100), and I've also gotten the newer FX-8320 stable at 5.03GHz (But run it at 4.65). Also have a sandy bridge i7 pretty high up there (4.89GHz I believe it was last), anyways!
I have a question concerning RAM. Obviously the function of the big 4 in timing is pretty obvious. You know, your 9-9-9-24, etc. I also understand that higher frequency reduces latency and speed, but tighter timings are vital as well.
My question is, what impact do all of the other CLK settings have on RAM performance? I run my RAM (On my Phenom II rig) at 1742MHz at 9-9-9-20-28-1T, which is as good as it will get on those numbers (It is G-Skill's non performance ram). I run the higher frequency due to a high FSB / NB increase. Does tightening things such as Precharge time have a noticable influence on performance? I've been able to change these settings, sometimes to their absolute minimum without much of an impact on stability. Some timing tightenings in these fields seem to increase performance, while others seem to actually slow the RAM down.
Research online seems to be a bit mixed, hoping somebody here has more practice / insight than me on this matter. Thanks!
