I'm planning to buy a new computer very soon, and after thinking about it for a long while on and off, I desided to go for the AMD option + overclocking.
This is my future setup:
CPU: AMD athlon 64bit 3000+ (s939)
Graphics card: GeForce 6600GT (PCI-E, 128mb GDDR3) by XFX
Memory: 2 x 512mb Crossair value (2.5 CL, 400mhz)
HD: Maxtor 80Gb (or 120, havent desided yet) SATA (8mb)
Motherboard: Epox EP-9NPAJ
And that's about it. I went for the epox motherboard because everywhere I checked it said that epox motherboards are the most stable when it comes to overclocking.
If I'm not mistaken, the cpu I'm gonna buy will run at fairly low tempetures, and that will allow me to overclock it a bit (or maybe it not as tiny an overclock as I think it is?). I'm planning to overclock it to around 2.4Ghz (the defult for this one is 1.8Ghz), after reading that the CPU can take it without to much trouble (even with the standard CPU fan issued with every CPU). Of cource I'll always prefer stability and lifespawn.
As reference:
http://www.hexus.net/content/reviews/review.php?dXJsX3Jldmlld19JRD05MzM=
I think that a good strong CPU fan will keep the tempetures way in the safe zone even if I'll overclock it to 2.4Ghz (feel free to correct me at any point)...
So I have a few of questions:
1) I've read a bit about overclocking but I'm still not sure, so in order not to fry my future PC I'll ask: there is no problem with overclocking the cpu only, right? Or do I have to overclock my RAM (for example) to fit the new overclocked CPU?
2) Assuming I overclock the CPU only, the parts I've mentioned above in a not overclocked status wont bottleneck the potential preformance of the CPU, right (seems like they wont)?
3) Again assuming that I overclock the CPU only, will it cause other parts that are not overclocked to generate more heat?
4) Is the lifespawn and stability of the CPU affected by it's tempetures only? Or are there other elements that effect it (elements which are related to overclocking)? If for example I overclock a CPU from 1Ghz to 3Ghz while keeping it running at 30C, will it shorten it's lifespawn or stability?
Thanks for your time
As reference:
