- Mar 28, 2003
A twist on computer naming! :::COMPLETE:::
Since about a year and a half ago my main computer's name has been HAXOR. I upgraded last year to a new computer, but my old one only had the name for about 5 or 6 months. I decided to keep the name with the new computer and my old setup now goes by the name of Haxor-Jr. Otherwise, I do a name change for computers when a new case is brought into the upgrades.
Given the fact I plan to keep this Lian-Li V1000B for another year or two, I decided to give this case some character and brand it.
With a logo designed by shard, I went to work with Photoshop and a couple pictures of my case to get an idea of how it might look. After trying out several locations where I could have placed the logo and a few different experiments of "glass" types for the cut, a couple hours yielded me this result as a winner:
The next step was to figure out a way to transfer this logo to my side panel, preserving the straight lines. The answer to this problem… A stencil! I printed this up so it was the width of a printed document on an 8 1/2" x 11" sheet of paper, then taped it to a sheet of thin cardboard. Following up by cutting it out with a steel ruler and an Exacto knife, this is the end result:
After stenciling it to the backside of the side panel using a #2 graphite pencil...
I used some of that blue painter's 2" masking tape to cover one side of the panel to avoid damaging the black anodized finish.
After about six (6) hours of a little Dremel work, drilling (See post 4) A LOT of filing and some 600 grit sandpaper to clean up the edges, I received this:
Now that the cut was finished, I used some 1/8" non-glare lexan for the window. I plan to scruff up the backside of this to make it frosty. To secure the lexan to the case, I used some double-sided foam scotch tape.
And now the fruits of my labor.....
It's just what I was wishing for! I can't wait to get the window sanded down a bit for the frosty look I'm going for and then find a white LED light bar or a 4" white CCFL to finish it all up. Updates to come when more work is done!
