Hi all,
Ok, i have build a budget gaming rig and I've got a problem with overheating,
my processor is AMD A10-5800k. By the reviews, my temperatures are way too high. On stock cooler i was getting about 60C in idle and didnt risk going full load, and with Arctic cooling freezer 13 it was 35-40C idle and 80-83C under full load using prime95.
I have read that the max safe temperatures for 5800k is 74C and im afraid that i will damage it....
In both of the cases i was using Arctic MX-4, i have used different amounts of thermal paste and always the same result ... so i guess its the CPU itself that it the problem.
Also this looks odd to me, when its under full load core speed range 3799.99 MHz-3999.84MHz where as it should be 4.2GHz and core voltage 1.248V-1.404V.
Thank you for taking time reading this, and i hope i will get my problem solved.
