A64 101
I think you have TCCx based modules. 2.8 might be overkill for em. Try using 2.6 or so. To get the CPU running at 2.4ghz and the mem runnning at 200MHz, you need a CPU/12 divider. To access this, you can set your multi to 10x, and set the 166MHz memory parameter in BIOS. Then increase the HTT to 240MHz.
Those Hypertransport speeds refer to HT multipliers and not HTT speeds. 200 would be 1x, 400 2x, 600 3x, etc.
Just wondering, if you try to sell me merchandise, why do I have to contact SSS?
Anywho, great guide, helped me out a lot with my first A64 build.
Cheers
very informative. i'm still with my old athlon64 venice (great overclocker, generates less heat when compared)
