- Aug 7, 2009
- Minnesota
I'm pretty new to overclocking, though through trial and error, I have managed to get a decent boost, but I'm hoping to get a bit more without having to make any hardware changes. First off, what I'm running.
-Asus A8N32-SLI Deluxe mobo
-AMD Athlon 64 X2 4400+
-Matched pair Corsair PC3200 1GB RAM chips
So far, by following the settings in another post on here, http://www.ocforums.com/showthread.php?t=468038 , I've been able to pull 2.6GHz. I did limit the memclock value to 200MHz, but left the MCT timing mode set to auto. With those settings changed, the system runs just a bit warmer than normal, but with them set to auto, I actually run 4-6 degrees C cooler running 2.6Ghz than I do at the stock 2.2. Don't see how that could be, but it is. Any more info, or perhaps a full profile would be wonderfully helpful. I've tried other profiles, but they are set up for different CPUs, and most cause my system to stop posting, and I have to reset CMOS...that's getting -old- considering the jumper is directly beneath the PCI-Express clip.
