- Apr 23, 2011
New to the forum. My PC was only modestly over-clocked (using AMD software) but this was reverted to "standard" some time ago. It has been running fine for several years since then.
My desktop died recently. When switched on, mobo fans work but no POST beeps. There is no video at all. Light for power and HDD come on. The HDD goes off after about 20 seconds. No flashing.
It started acting erratically during boot-up (sometimes failed, sometimes locked). Never got to BSoD so either it booted to Windows OK or just crashed in the boot, prior to initiating windows.
I have stripped the board to;
- mobo
- cpu and heatsink
- PSU
Connected the onboard sound to a speaker and no POST beeps in this config. Tried removing the CPU and the AMI-BIOS voice fault detection stated "no processor", so the sound works!
I have tried a new PSU that I know works, so the problem is not voltage and power. I am pretty confident about that.
I have tried resetting the BIOS using the "battery out" method. No change.
I have tried two different graphics cards
I am just about to bin the entire system but was wondering about buying a new AMD-939 CPU just in case that is the culprit (the OEM versions are <£20). The PC would still be useful for the kids.
Grateful for any suggestions about any further diagnostics or tests I can run to determine if it is the mobo or the CPU that is faulty, please. I am a complete beginner, so no access to anything except a cheap multimeter and a 5lb hammer.
Thanks for any suggestions.
- mobo
- cpu and heatsink
- PSU
