- Nov 23, 2004
- Missouri, USA
? about Abit IC7-G and the Serillel 2 tech..
I recently upgraded my HD to a 74gig Raptor this weekend and while I was installing windows I got to sifting through my IC7-G max II box and low and behold what did I find...a Serillel 2 adapter. I thought to myself, "Self, what the heck is this thingy?!?!"
So I proceded to read on the website about the adapter and how it will convert an IDE hard disk to a SATA interface. So that seemed pretty cool to me as I could use the space, and the airflow.
Has anyone had any expereince using this little gadget. I have a IDE hard drive that has my music/pictures/downloaded files on it and I would like to be able to use this little adapter so I don't have to put in my rounded IDE cables again, plus I read there is a "slight" performance increase.
My question is though, after reading a little more, it seems that you must use the Silicon Image Controller, and I have already installed my Raptor using the Intel southbridge controller. Do I have to reinstall windows and use the SI driver at the portion of setup where it prompts you to hit F6 to install the SATA controllers, or will I be able to just unplug my raptor and plug it into the SI controller? Also in the diagram it mentions that I need to set the jumper on the hard disk to the "master" position and of course, I want my Raptor to be my master, Windows and program files partitions. I just want to use this as a storage device. Maybe I should email Abit tech support about this, but just thought I would post up here and see what you all had to say about the issue.
Any questions/comments on this gadget would be greatly appreciated!
