jackthebox
- Apr 17, 2013
bought accelero xtreme 5870 for my Gigabyte 5870 that had original fan failure....
well the 4 pin (red,black,yellow,blue) cable coming from the accelero xtreme is too short to plug into Gigabytes plug... and the plug is only 3pin(red,black, yellow)
were can I buy a 4 to 3 pin extension cable only need 4inches... I know about blue wire and don't care about it.
I do not have any power take offs on my power supply I can use for molex kind,...... also my 3pin plug on the card does not just have pins sticking up it has a surround so a 4 inch 4pin extension cable would mean I would have to mod the plug on the card to or on the extension....
hope I am making sense.
