- Sep 30, 2020
Hi there!
Being an amateur when it comes to RAM and tweaking RAM, I've been trying to do my best to read into articles and forums surrounding the latest generation of ZEN 3. To not waste too much of your time, so to speak
I would like to break down what I'm trying to achieve in the order of my priority:
1. I'm looking at 64 GB of RAM
2. I'm looking at 3800 or 4000 MHz
3. I'm hoping to keep the voltage at a maximum of 1.4 V
4. CL 16 would be great, but I might be dealing with CL 18
I'm also looking for a solution where I don't have to physically be upgrading the system with a custom loop or whatever. Just plain and simple by manually entering timings (if needed at all). I don't like to max out things to the degree where it might cause damage. It's a simple 'attempt' to see how far I can get. Not to make a sport out of it. If it turns out that's not possible, I'm still happy to use a set that seems like a proper fit.
CPU/MOBO: AMD Ryzen 9 5950X, ASUS ROG Crosshair VIII Dark Hero
The Dark Hero has 4 DIMM slots. From what I read, two modules are preferred over four modules. In other words: 32x2 GB modules. The alternative would be 16x4 GB B-die modules, but I'm not sure how much that would lower the performance.
I'm really hoping for an answer, other than sticking with 3600/CL16 speeds (unless it's better to overclock from here on?). I know the 3600's are very common and popular, but I was really hoping to get into the range of 3800/4000 MHz.
The recent announced G.Skill Ryzen 5000 (Neo) modules seem like a great solution, but from what I'm reading, some of these might never see the light of day. Especially the 4000CL18 32x2 GB kit. The F4-3800C18D-64GTZN kit does seem to exist. Which would probably be my back-up option.
So with all this information: what would be the best combination to go with which is also compatible with the Dark Hero? For sure G.Skill sounds interesting, but there are other brands as well. However, the 'popular' sets from those brands (such as Corsair) don't seem to be confirmed/working (yet). There are a lot of sets going through my mind right now, but I can't really find benchmarks/reviews/comparisons about the 'drops' in performance in some scenarios. For example, running two identical sets of 16x2 GB (the question would be how the motherboard will deal with two sets). Another scenario would be running 16x4 GB modules, but than the question is how much performance I will lose compared using the preferred amount of two modules (would the B-die tweaking options make up for that?). And than of course the 32x2 GB sets, which don't have B-die options (so basically you're doomed with lower CL anyway).
I hope all of this made sense Please keep in mind that I really am an amateur when it comes to RAM timings. To spare you some time, I'm not expecting you to explain things in depth.
Thanks for now!
Thanks for now!
