GTX_SlotCar said:
Did you do them all at once, or did you do one at a time and test each one?
You'll have to test each stick to find out if the problem only exists with one of them. The problem is, you may blow your SB again.
Either way, you'll probably have to take the copper heat spreaders off and examine the chips with a magnifying glass.
I believe, if the heat spreaders are hot, they're working.
Gary
they were getting hot before i removed the heat spreaders and yes, i have examined the one that was not working right w/o the heatspreader and i could not find any sort of scratch or apparent damage, and I know it was the one that did not work because the others all work fine. This is really wierd and im not sure how it blew my south bridge which sucked. im not sure what to do at this point. try and see if it will work on the new motherboard? or should i just go ahead and rma this one? i put on the original heat sink and it looks good from the outside, you think it will fool vitesta? and since i got these from new egg, who should i contact, newegg or vitesta for the rma? i hope it works. thanks for your help in advance
