- Aug 23, 2007
The case is a Phantek Enthoo Luxe 2 (don't like the new 719 name)
8700k delid running at 5.2ghz can bench at 5.4ghz no avx. Vega 64, Gigabyte Z390 Master, 64 GB ram, 20+ TB storage.
Water temps used to avg 28c and now they are 25c solid after adding this EKWB 250ml RGB reservoir. I have a 60mm 360 rad up top, a 26mm 360 rad on the side and a 26mm 480 rad in front. All silent wings 3 fans from bequiet. At 5.2ghz a blender benchmark run I'm in the 18+ minute range with max temps of the 8700k at 79c @1.45v.
This system will be upgraded to the TR 3970X in a few days w/ the Gigabyte Aorus Extreme (or Master, depends on what Microcenter has in stock). Will probably use EKWB's newer revised cpu waterblock to cool that thing unless someone has a recommendation for a better block to cool the 3970X.
