- Oct 4, 2002
I decided to wait with a full rebuild to Skylake (MB/DDR4/CPU) and just add more memory to the system I have, to get better performance in video editing.
You can see my specs and build in my sig.
I understand that triple channel is used with three identical sticks in the same color slot. If I buy 3 sticks (3X8gb) for a total of 30gb and just put them into the three free slots, will this work?
Or do I need to remove the once I have and add 3 higher capacity ones?
How about timing and voltages? does it matter if the three new sticks are 9-9-9-24 or whatever?
Any suggestions of good memory to buy? ~$150
Anything else I need to be aware of?
thanks for any help.
