Hey everyone,
Currently upgrading from the rig in my signature. Will be upgrading to a 5820k. I would like to run the 5820k @ 4.5GHz or better reliably (and always wanted to build a custom loop, so this seems like a great excuse to finally do so )
I'd like to keep the build at or below $400, but if I go over by a few dollars, so be it, but ideally I won't go over the budget.
Here are the parts I've selected so far:
1. XSPC Raystorm Pro CPU Block ($75)
http://www.performance-pcs.com/xspc-raystorm-pro-cpu-waterblock-v2-intel.html
2. Alphacool VPP655 Res. / Pump Combo ($158)
http://www.performance-pcs.com/alph...ol-lighttower-all-in-one-reservoir-combo.html
3. Black Ice Nemesis 240gtx ($88)
http://www.performance-pcs.com/blac...tealth-dual-core-xtreme-profile-radiator.html
4. Various fittings/tubes/coolant
Grand total for everything is at $377, so I'm very happy about that, so long as these are quality parts.
While I'm not overly concerned with noise, I don't want it obnoxiously loud either; looking at the specs, the radiator looks like it should give the performance I want without requiring crazy loud fans (but I could be wrong).
I'm guessing the pump is probably a bit overkill, if there is such thing when it comes to pumps, but I want the option to add the GPU and another radiator down the road if I decide to cool a pair of GTX 970 in SLI.
Is there anything glaringly wrong here? Or perhaps I could get better value for the money with different parts? Any feedback or advice for a first time waterhead is greatly appreciated!
