Alaric
- Dec 4, 2011
- Satan's Colon, US
Next month I'm buying a D5 pump (already ordered a dual bay reservoir). I've been eyeballing Swiftech and Alphacool because that's what people seem to have in stock. I like the 1200 to 1500 l/h and 12+ ft. head pressure of the 655 pumps so far. It will be a single loop with a 240 rad due to case restrictions. Should be room for a reasonably thick rad, maybe push-pull fans if necessary.
I'll be cooling a FX 8350 and OC'ng it, hopefully to 4.6? 4.7? As far as reasonable with available cooling. The rig never gets stressed and C&Q, etc., will all be enabled once the OC is set. I want the extra juice available just because, LOL. It plays solitaire and scrolls FB, so I want massive overkill. Anyway, any recommendations on reliable D5 pumps? And is 1/2"x3/4" tubing too much? I want good flow, but if it's just going to sit there waiting to get through the waterblock and heat soak then it's counterproductive. My thinking was quantity of coolant at low pump speeds will be easier on parts and quieter. I'm open to input and experience here, though.
This is the waterblock. It's black and RGB and goes with her build so we're getting this one. LOL http://www.performance-pcs.com/xspc-raystorm-pro-rgb-waterblock-amd-am4-black.html
