- Sep 15, 2009
Hi Everyone,
I'm new to this forum, but I've heard great things about it from looking around the web. I'm currently in the process of building a new system, and would like to watercool it. Ultimately, I would like to be able to OC on both my CPU and GPU. I've done quite a lot of looking around, but can't seem to decide. I have a pretty decent budget for the cooling system (around $700 CDN), but don't want to waste it away either. I'd like to spend every cent on quality materials. I have done some WC setup in the past, so have some confidence in it. However, I'd really like to avoid any high-risk modding procedures. Also, I prefer to keep my system organized, and avoid having to build a custom chassis to house the WC components. Any advice would be greatly appreciated. Please also feel free to give me feedback on any component of my setup (in addition to the WC)
First off...my system (changing things as i change my mind through this thread):
Cooler Master ATCS 840
ASUS P6TD Deluxe
Intel Core i7 920 Quad Core Processor LGA1366 2.66GHZ
Corsair XMS3 Dominator TR3X6G1600C8D 6GB DDR3 3X2GB
Western Digital Velociraptor WD3000HLFS 300GB SATA2 10000RPM
Western Digital WD15EADS Caviar Green 1.5TB SATA 32MB
2 X ASUS EAH4890 850MHZ 1GB 3.9GHZ DDR5 PCI-E (in crossfire)
ASUS Xonar DX 7.1 Channel PCI-E Sound Card 24BIT
Current Cooling System
HEATKILLER® CPU Rev3.0 1366 CPU Water Block w/ Heatkiller 1366 Backplate
Swiftech MCP355 High Performance 12V Industrial Water Cooling Pump
XSPC Laing DDC Reservoir Top for MCP355 Water Cooling Pump G1/4
Feser Xchanger 120.3 Radiator w/ Scthye GT Fans
Bitspower Mesh Radguard 360 (3 x 120mm)
Scythe Kaze Master Ace 5.25IN Bay 4 Fan Controller
HEATKILLER® GPU-X² 4870/4890 Water Block for ATI 4870/4890
Bitspower -TRUE GOLDEN- G1/4 Straight Compression Fittings
Bitspower Black Sparkle Single G1/4 Rotary 45 Degree Angled Fitting Adapter
Tycon Silver Anti-Bac Tubing
Ultimately, if possible, I'd like to watercool at least my CPU and GPU, with chipset being a bonus. I've looked into a koolance system (which fits my budget) but have read that they are not worthed the price after all. So, I checked out the Apex Ultima Plus...but seems like they don't have a block for my GPU. Also, I don't exactly know what the cooling requirements are for my system with OC. I had a zalman reserator v2 with my last kandalf system....and it died...so this time..looking into custom cooling.
Once again, really appreciate all your help..thx so much!
Edit:
I also have some questions about RAM cooling. I see that a lot of systems have fans over the RAM. Is that included with the Corsair memory that I chose? Or, do I need to buy it separately/will it fit? Thanks!
ASUS P6TD Deluxe
Edit:
