- Oct 11, 2002
- The Empire State
If the Feser is both 60mm thick and a 120.3 radiator, then I don't see how you could do push-pull when mounted up inside the top of the case. You could do either push or pull, but not push-pull. Like I wrote above, you have 100mm of head room, 104mm if you push it (with 1mm to spare). To even get 100mm you have to remove one removable cross-brace (which is not a problem, it's meant to be removed). You definitely do not want to remove the cross-brace that is physically attached to the motherboard tray itself though and that's the one that limits you to 104mm of headroom. But I don't have a Feser radiator. I have an MCR-320 @ 34mm thickness. Perhaps Nebulous has a Feser and knows something we don't.
Ahh, I missed/overlooked the part he was using both a Feser & a PA120.3 rads in the one case. What I should have said was if he used one or the other but not both rads. Sorry for the confusion.
I also have the MCR320, but mine is mounted in the rear of my RocketFish with a radbox.
*Edit*
Now looking at the Thermaltake Xaser VI case, his best bet would be mounting the rad @ the rear where the 120mm fan is with a radbox and running the lines inside the case. The bad part of this scenario would be the mobo tray will not be accessible.
He can also do this with the Antec P193, but no problem with the mobo tray as it's non-removable.
