Hi guys,
I've decided to delve into the world of water cooling, and I feel like it is time to ask for some assistance.
I've been reading a crazy amount of information and I can't decide on what to get and was hoping for some advice.
My specs are:
CPU - Intel 2500k
GPU - GTX 770
MB - Asus P8Z68-V/GEN3
PSU - 750W (I forgot the exact model)
Case - CoolerMaster Silencio 550 (mid tower)
My goal is to run silent, cooling both CPU and GPU in the loop, since my computer is next to my bed and also just for general quality of life improvement. No crazy OC, but I'll take what I can get while still running silent.
So far I've settled on the pump, Eheim 1048, but i have no clue on which or how many radiators to get, and I just get more confused the more I read and due to the amount of choices. Although i kinda like the Coolgate 120 mm radiators.
As for fans, I've been looking around and the information I find just seems to be outdated, I found Scythe kame flow II as one of the better alternatives to GT AP-15 (which I am not a fan of based of user comments of whiny noise at max rpm), but it is no longer in production.
As for reservoir, I'm going for a T-line.
For CPU and GPU water blocks I'm not really sure. The EK blocks are good?
And if possible i would like to keep it inside the case.
Budget wise I am not looking for high end stuff, but I do have money to spend for quality product that will last.
I appreciate any advice you can give, and any other tips you might have for creating my loop.
-Chris
My specs are:
CPU - Intel 2500k
GPU - GTX 770
-Chris
