Hi people, just wanted to run my parts list past you guys see what you think. I've built a couple systems in the past and as well I have been doing my research into the best bang for the buck, on a bit of a budget as I am building two of these, one for me and the wife. We mainly game but as well do some video editing/encoding, sound production, Java development, anyways let me know what you guys think please? Much appreciated
Here is the rundown of the base components and explanation as to why I am picking these and maybe help give you guys an idea behind the choices.
PCPartPicker part list: http://pcpartpicker.com/p/WDtwt6
Price breakdown by merchant: http://pcpartpicker.com/p/WDtwt6/by_merchant/
CPU: AMD FX-6300 3.5GHz 6-Core Processor
Because Zen comes soon and I do not see the point in an extra $50 pricetag for 2 extra cores.
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler
Because I would like to overclock to around 4.5 without worrying about temperature issues. Will be front mounted for fresh intake against the fins. Also picked this due to it being one of the CoolIT made not Asetek which have been not performing as well which I suppose why Corsair went to CoolIT.
Motherboard: Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard
Cheap 990fx that will get the job done and is ASUS quality.
Memory: Crucial Ballistix Tactical 16GB (2 x 8GB) DDR3-1866 Memory (
Pretty much the cheapest Cas 9 16GB kit available with decent reviews and specs.
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive
Has some of the best Read/Writes (560/510 MB/s) for any SSD 240 GB under $75
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card
Just overall my favorite 960 card for heat control, would like to get the 4gb version with a backplate if it goes back on sale again but at $200 it's abit steep.
Case: Thermaltake Core V31 ATX Mid Tower Case
One of the roomiest cases for the price range and easily fit everything as I will not be using hdd trays at all, the ssd above will be mounted behind the mobo or below the optical drive.
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply
I like EVGA can you tell? Anyways just a good and quiet psu that should easily cover my wattage and I do not plan on running dual GPU so should be good, actual wattage will look something like this (Upped the stats abit to hopefully cover overclocking) = http://outervision.com/b/R66bDI
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Just a drive I will almost never use.
Case Fan: StarTech FAN5X1TX3 8.6 CFM 50mm Fan
For the back of the socket, Told you I've been lurking
Case Fan: StarTech FAN7X10TX3 70mm Fan
For the NB area, Told you I've been lurking
Case Fan: Kingwin CF-014LB 58.0 CFM 140mm Fan
These both will be on the top of case as exhaust.
Beyond that the case comes with 2 120mm fans one in rear as exhaust that will not move and one in front that will be moved to the bottom of the case as additional intake.
This will all be bought from Amazon due to prime free two day shipping, so the price total listed at PCPartPicker is not accurate.
That's the gist of it just waiting on my refund, so whatcha think?
