- May 13, 2006
Ok so I bought this kit http://www.ekwb.com/shop/kits-cases/kits/ek-kit-h3o-240-hfx.html on a whim at Micro Center the other day as I've been wanting to jump to water for a long time. I'm very pleased so far with my purchase other than (and I was kind of expecting this when I bought it) the only way to mount that thick rad was in the lower front of my Fractal R4 which has now caused my GPU fans on the 970's with EVGA ACX coolers to spin up above the noise level I'd like to have (the top stays just below 50% which isn't terrible just louder than I'd like).
My questions would be how much more rad would I need to add to put the 970's in the loop while keeping noise to a minimum, noise is more my concern than temps really as long as the GPU's stay decently cool.
I'd like to try and keep it all internal in my case ans replacing the case isn't an option at the moment. The options for placement are single 140mm in the rear and bottom and the top is tricky, 280mm won't fit due to the 8 pin power plug on the mother board and it looks like I could get away with a 30mm thick rad up top.
