Hello everyone!
I am new to these forums and would love some advice on my AMD Phenom II X6 1050T overclock.
Specs:
CPU: AMD Phenom II X6 1050T (Socket AM3 - Thuban) 2.8GHz stock
GPU: NVIDIA GTX 650 Ti
RAM: 8GB (4x2) DDR2 800 PC2-6400 (CL5-5-5-15 1.8V stock)
MB: Asus M4A785-m
Cooling: Gamer Storm Captain 120
PS: Corsair RM1000 W
Airflow: 1x140mm front intake fan
1x120mm bottom intake fan
1x120mm side intake fan (over GPU)
2x140mm top exhaust fans
1x120mm rear exhaust fan (push setup through water cooled radiator)
Overclocking settings:
CPU-Z
So far I have overclocked my cpu to 3.85GHz with prime95 stability test over 2 hours passing all blend tests. Idle temps are 32C and under stress testing average around 51C and max 56C. I would like some advice on my temps, voltages, settings and whether they look correct or not.
Also my HT Link Speed only goes up to 1400MHz in the bios. Is this speed good enough for the higher CPU/NB speed as long as it's below it?
Any help and advice would be greatly appreciated! Especially how to get my oc to 4GHz.
Specs:
MB: Asus M4A785-m
CPU-Z
