I see your problem, your OCZ is the newer Winbond CH-5 based modules, am I right?.
The bottom line is the AI7 does not so well when you go past 250 with CH-5 using either the 5:4 or the 3:2 divider. Yet does nicely when below 250 with 1:1 (but the graphical artifacts are not to nice)
Yeah, It will NOT boot at 275 no matter what CH-5 tryed in the AI7, no matter what slot, set, or timing.
Around 270 it often will not boot, Around 265 it boots 95% of the time.
Good news is you can get alittle more out of by using Uguru in windows.
Just make sure you move the fsb back before you exit, otherwise you won't be able to boot again
I also found out the AI7 really sucks when trying to load up all 4 dimms with just BH-5(every setting sucked bad). Yet does well when just 2 dimms are used(massive overclocking potential)
The AI7 does well with all CH-5 when all 4 dimms are used(overclocks great but artifacts at lower fsb). Overclocks almost as well like when using 2 dimms.
The AI7 does great when BH-5 and CH-5 combo are used when all 4 dimms are used, good stability, also was able to obtain lower stable latency of the CH-5(magic
). Just check my sig and you will see why im mixing. (massive reduction in graphical artifacts, as a bonus extra)
