- Aug 31, 2002
- Huddersfield, UK
Hi.
Basically I want to know what setup to have to get good airflow. At the moment im just using my old P2 450 but I am going to upgrade to an AMD 2ghz chip very soon.
I have a full size tower with a fan blowing air in at the bottom front of the case. Then I have the psu directly above the processor sucking air out of the case. Then right at the top back panel and top front drivebay of the case I have fans sucking air out of the case.
Is this setup any good because I have 3 fans sucking air out with only one sucking in? At the moment my motherboards temp probe reads 29 degrees Celcius and never goes over that. The cpu temp is usually below 40 degrees Celcius even uder load, unless I overclock it too 540mhz and 2.3v. Then the temp of cpu goes up to 49 degrees celcius under load and the system goes to about 32degrees.
Im also going to add a window kit with a blowhole in it...now which way should the fan blow...in or out?
All this is too confusing.
