- Aug 6, 2001
- Chanhassen, MN
Does anyone know if the Alpha PAL 8045 heatsink will fit on the AK31 v3.1 mobo? Thanks.
DodgeViper said:ymNA, sorry to break your bubble, but you do have to cut the sink.
Alex99, You have to cut the HS to clear the fan and the green cap. If you do not cut for the fan then the HS compress the spring on the fan mount. You want the HS to sit flat on the CPU. The cap cannot be pushed out of the way as it is soldered flat against the board. You also need to cut some of the nylon washers so they sit flat on the MOBO.
I used a 1/4" metal cut-off tool in a drill press. I used the drill press as a mill and hand fed the HS into the cutting bit to remove the metal that came in contact with fan mount and cap.
You could use a round file and do basically the same thing though.
If this is something you think is over your head, ship it my way and I will remove the metal for you at no cost other than to ship it back to you. I will even lap/polish the HS for you.
Its really very easy to do.
Alex99 said:
for your great offer, but I've ordered a Millennium Glaciator already.
