The pump/res is being mounted towards the back of the box away from the fan. It will be like this if you look at the radiator. Space for 120mm fan |Pump/Res| Space for 2 120mm fans.
The way I measured everything I will not need any 45 or 90 degree connectors. Final version will have built in quick disconnects so the external cooling system can be disconnected from the case.
