- Jan 4, 2007
So I've been researching parts for a soon-coming-but-long-overdue upgrade. I always use the AMD Processor lists on Wikipedia as a starting point and then research from there. So I'm looking at the new Phenom II X4 processors and see that the AM3 boards just came out last month. However, I'm a bit confused by the clock speeds listed.
The AM3 CPU's range from 2.5 to 2.6GHz with 4MB or 6MB per core of L2 Cache and 2GHz HT on all 3 CPU's, whereas the AM2+ ones go from 2.8 to 3.0GHz with 6MB L2 on all and 1.8GHz HT on all. I know that Intel and AMD want to get away from the Clock Speed being the number one determination as to what processor is the fastest, so I'm here now to ask, between the AM2+ and the AM3 models, which is the faster CPU at it's stock settings, factoring OUT memory and motherboard?
The reason I ask this specifically is that I do not plan to do overclocking, and I plan to ask similar questions in both the Memory and Motherboard forums once I have an answer here, so that I get the best Mobo and fastest memory as well. I'm already using an 8800GTX, which is more than suitable for WoW, but my framerates are suffering from the CPU and Motherboard I use.
