- Aug 30, 2004
- Santa Barbara, CA
AM2 X2 3800 [Build Log 56K Warning!]
Folks,
Lucky people like me get to build computers for University research. This is a budget build for internet surfing and light computational tasks
Components:
Without further delay, lets look at the components first.
Motherboard (ASUS M2N-E):
This is a rather light-weight board! It is smaller in size than the DFI-NF4 series I've owned and a bit smaller than the ASUS P5W-DH 975X. It measures 12 x 9.5 inches. This board requires an EPS 12V capable PSU!
The layout:
Cap Report:
The little ones say "TK" which means they are manufactured by Tosin Electronics Co, Japan. Relatively unknown and not a good company according to a few electronics threads I came across. For example, THIS is one such thread.
LINK TO DATASHEET (pdf)
The big boys you see below are made by Panasonic, a very well known and reputed brand with a low failure rate and low ESR. Note that in this and the previous pictures, ASUS have skimped out a bit on adding a few more caps. Clearly, those empty slot next to the Panasonic is for another cap. I bet you will not see this with the SLI/Premium/Deluxe version of the board. If this were my personal build, I would add the correct cap immediately.
This is how the socket layout looks. I'm not very happy about the proximity of the capacitors to the big heatpipe cooler. However, those caps are all Panasonic, so I think we should be o.k here. Again, if it were my personal build, I'd slap a fan on the heatsink. This rig will be overclocked only for testing purposes, but it will run completely at stock otherwise.
Now, lets take a look at some of the Aluminum-electrolytics being used. Actually, that's the only one I could find on the board. I'm not sure who makes them, so I'll update this part when I find out. Again, notice the vacant spots where the caps ought to have been. Cheap ********..lol! The 975X has zero empty capacitor slots. Well, this is clearly a cost cutting measure. Can't blame ASUS for it.
Don't go away! More to come!
S-N
Folks,
Components:
[*]ASUS M2N-E NF 570-ULTRA
[*]AMD64 AM2 X2 3800
[*]RADEON X850XT
[*]OCZ POWERSTREAM 520W
[*]LITE-ON 16X DVD-RW
[*]PQI TURBO DDR2 533 (MAB42GUOE-X2) 512 X 2 Mb
[*]SEAGATE 160 Gb SATA-II
[*]SONY FDD
[*]THERMALTAKE MAMBO CASE
The layout:
Cap Report:
S-N
