- Dec 19, 2012
The MOSFET does not deliver a signal, it delivers only DC voltage in a pulse form to the inductor that changes it to continuous DC with the capacitors. The operating range of the MOSFET Temperature and Frequency is set by the motherboard companies and is FOOLPROOF. When you see 1.425v with a Digital voltmeter that is what the VRM is producing for DC voltage even when running the MOSFET at the highest factory calibrated temperature before throttling and shutdown.
Dolk is correct if the factory parameters were off we would see Mosfets buning up and massive complaints in the forums and review sites demanding the manufacture to take care of the problem. We don't design motherboard VRMs here, so folks don't have to worry about running a 4-2 phase with 1800X because manufactures set the calibration so that you will make it through the warranty period.
Most people don't even join forums when building a PC manufactures have to make the motherboards foolproof. I will give one very small manufacture example So if there is even a slight problem like EVGA had folks would find the problem in motherboards by the masses.
The best selling motherboard at Newegg is 4+2 phase GIGABYTE GA-AB350-GAMING 3.
Well as a quick recap at the FX launch I recall many boards (MSI) going down in flames and twice as many throttling the speed. The OEMs don't always get it right. Just because the board is popular doesn't mean it's a great board it just fits the price range usually.
Like it or not electricity is a signal and it has a range that needs to be met or things fall apart
