- Jun 5, 2009
- Sydney, Australia
It's summer here in Aus; and it's quite hot.. Fully stressing my 1.25v 4GHZ i7 930 gets me over 80 degrees.. So i decided to throw it back to stock at 2.8ghz with 1.15v. Last NIGHT; I ran IBT to check temps; highest temp was 68/69, lowest 63.
If I had run that during the day I would've expected 72-74 ish degrees as top.
With that being said... I decided to clean my computer (to a degree) of dust.. specifically my heatsink/two fans. I didn't realize the amount of dust I had let build up! Clump after clump.. Ha! Put it all together...
Then ran IBT Very high at 2pm (so decent heat time.. My room has very high ambient temps; almost as hot as outside (27-28 degrees Celsius +). I'm lucky our summer isn't as hot as normal.. Normally my room would be 30+ lol.
Now the temps.. Before a night run of IBT was 63-69... Now I'm running 63 as a MAX on the hottest core; with 59 as the lowest.. So factor in the temp difference (4 odd degrees). A solid 10 degrees Celsius was lost from just a little dusting..
Amazing.. Lol.
Anyone else got any dusty stories? XD
Amazing.. Lol.
