So I managed to overclock this processor on a ASUS motherboard with few different values. Take a look.
Computer Specs:
Working Values w/ Aircooling:
Experimental Values w/ Aircooling: (I've had trouble with these on Windows but the computer still turned on fine) (it may or may not work for you guys)
I also have done benchmarks to test the heat capacity it gets in Celsius for 1 hour but it didn't get any higher than 55C maximum the minimum is between 40C-52C
Ps: ( I also have 5 fans in my tower that could also be a key benefit on why it's so low (excluding the CPU fan then that would be 6 fans in total) )
Computer Specs:
Code:
Windows 10 64-bit
4 Gigs of RAM
AMD Athlon 64 X2 4050e (Original Clock Value = 2.10Mhz)
Asus M2A-VM HDMI Motherboard
Phoenix - AwardBIOS v6.00PG ACPI BIOS Revision 2302
Code:
Multiplier = 10.5 x
BUS/Frequency = 225 Mhz
Volts = 1.250 V
= 2.50Mhz
Multiplier = 10.5 x
BUS/Frequency = 250 Mhz
Volts = 1.250 V
= 2.65Mhz
Multiplier = 10.5 x
BUS/Frequency = 260 Mhz
Volts = 1.250 V
= 2.73Mhz
Multiplier = 10.5 x
BUS/Frequency = 270 Mhz
Volts = 1.250 V
= 2.83Mhz
Code:
Multiplier = 10.5 x
BUS/Frequency = 280 Mhz
Volts = 1.250 V
= 2.94Mhz
Multiplier = 10.5 x
BUS/Frequency = 290 Mhz
Volts = 1.325 V
= 3.04Mhz
Multiplier = 10.5 x
BUS/Frequency = 300 Mhz
Volts = 1.350 V
= 3.15Mhz
