- Jun 27, 2012
Hello everyone. I am a new user so please tell me if I am breaking any rules. I recently finished my budget build computer and saw that the FX 4100 can handle a decent overclock. My computer specs are as follows.
ASRock 970 Extreme 3 mobo
AMD FX 4100
EVGA nvidia 550 ti
8gb of ddr3. (corsair and ballistix)
Modular 650watt power supply
HAF 912 case from Cooler master
I overclocked the cpu from the stock 3.6 to roughly 4.4. Using HWmonitor and core temp, my core temps hover around 12 degrees celcius. When I used Prime95 to stress test, the comp freezes completely (no mouse or keyboard) about 10 minutes in. The temp leading up to the freeze are in normal range. (34-44C)due to the Cooler Master 212+ heatsink I got. Nothing has been touched other than the mhz. Why would this happen? At stock cpu speed, I can stress test for hours with no problem. Does this freezing mean I need more voltage? Could the two different brands of RAM effect anything? (they're the same speed)
AMD FX 4100
EVGA nvidia 550 ti
