pcformer
- Aug 3, 2017
- Southern Indiana
Hello Everyone!
First of all, I'm new to the forum, and quite inexperienced in overclocking. I'm not educated on much of the terms used, however I do know a little.
That being beside the point, I have my BIOS set up with the clock at 3600MHz/3.6GHz and the voltage set to 1.35. Keep in mind I'm running the stock cooler. Now, this being said I also have Cool N Quiet disabled, hoping to keep the CPU fan at 100% all the time. After setting the clock in BIOS, when in windows, even at idle, the processor is running at 3600MHz.
My problem comes in when I put the computer under load. In my case, running GTA V on PC. When in game, the temp reading goes up to 180 degrees Celsius or more. This number seems insanely hot to me, however, even before forcing the clock at 3.6GHz in the BIOS, it was still reaching these temps when in game. Occasionally the processor reaches temps of 200+ and throttles down to 1.4GHz. I need a fix for this. Is the stock cooler really this bad? I would understand the temps if I was running a crazy overclock, however, I'm just running .3 more GHz, which with AMD Turbo **** enabled, it goes up to on it's own anyway. It just doesn't make very much sense to me because it seems as if it was reaching temps like this even on the stock clock under load? This just seems crazy to me. It's like the stock cooler is just completely useless at anything other than idle. The spec temp for the processor is 70.
What's the solution here? Just buy a better cooler? Is the chip bad? I'm lost.
Thanks in Advance Everyone!
