Hello everyone,
I recently purchased the 8370 and am doing a tiny bit of ocing. I have an antec twelve hundred v3 tower. I do run aio liquid cooler corsair h80i v2 which did mean I had to remove one of the rear exhaust fans (bottom one) to mount it. So in total I have 3 intake fans in the front which are stock, in the drive bay area there was a fan bracket which i used and am using a cooler master 120 jetflo which is pushing that one intake fans area in as well which is straight across from the fans of the liquid cooler. I have the stock 120 rear exhaust fan that is above the radiator and the top 200mm fan. The stock fan that was the other rear exhaust I did mount but it's on the side of the hard drive bays just blowing air against the steel case in hopes it would help cool some what, I drew a red line of where the fan would be around. I don't have much room for more fans the side window mount cannot be used due to the radiator.
All HDDs are in the very bottom driver bay which is 2 hdds and 1 ssd. I have 4 sticks of 8gb crucial ballistix sport 1600 running at the profile of 1600 cas of 9.
SO let's get to the main question....I ran prime 95 for a little more then 29 mins and my CPU it's self stayed below 40 degrees Celsius...however the CPU socket was keeping around 65ish...i know the socket can get up to around 70ish before it's kind of a cut off. It is running at 4.6 and i can't remember the full numbers of the NB voltage, etc. Below is the image. I was just curious on your guys thought of the temps etc. Also if there is anythign I could do to get that socket temp down...i was thinking of possibly making a cut in the side steel cover where the cpu cut out for motherboard is and getting a fan mounted there to blow air on the back.
Thanks for the help! If i put this in the wrong thread area sorry in advance..I wasn't sure if should go in cooling it's self or more in AMD cpu,
