- Jan 10, 2012
you can make it easy and just cut the big hole, drill the 4 fan mounting holes and then use a cheap fan grill.
Hello everyone,
"I recently purchased the 8370 and am doing a tiny bit of ocing. I have an antec twelve hundred v3 tower. I do run aio liquid cooler corsair h80i v2"
Thats pretty cool!
I also have an FX-8370 on an ASUS M5A99FX-PRO Rev#2 Mobo and am cooling it with the same Corsair H80i GT watercooler.
I have it loaded into a older ANTEC 900 case which I highly modified for a "Hunchback or Backpack Rad Mod" with its rad Externally mounted in a push pull config. To cool my VRM's, I placed a 100mm 4pin fan which I rested on the back of my GPU card and have it leaning on an angle against the top of the water block. This is a temporary setup as I decide to either build a custom case from scratch(because I can't find one that fits my design ideas for long term upgrading and modding needs) or just get a Coolermaster Master Case Pro! I would rather the ATX Cube design I have in mind.
Anywho! I have also made a provision for adding another 80mm fan on the back of the mobo to help cool the socket. I had planned that from the beginning after seeing it in a You Tube video. But the fact is, with that 100mm 4pin moving a greater volume of air over the face of the socket as well as the VRM's, heat is no longer an issue AT ALL.
My case in point. I normally run my system in its non gaming "Silent" configuration at 4.3ghz all the time and the system temp never goes above 38C while I watch videos via streaming or play a torrented movie while I stream more torrents at the same time. It's effortless and has no heat problems even if I run a game while playing a TED video in the background. But when I want the higher FPS levels for gaming, I O/C it up to its median 4.7ghz for 100+ FPS and tweak my Sapphire R9 285X Dual-X Amethyst 2gb GPU up a notch. So far the highest temps a I have seen is the GPU hits 52C and the GPU tops out at 47C... Barely pushing either, and I have my watercooling rig set to a mild Balanced 2 setting I created that makes it just barely audible.
As for the potential of this system for Maximum O/C performance, I have barely touched it. Using AMD's OverDrive app, I was able to push the FX-8370 to 6.3 ghz before it glitched and reset. And it ran at that rate for over 10 minutes. Just to be sure I set her back to 6.2 ghz and it ran the stability test for over 30 minutes without issue. I'm just starting to play around with saved stable settings above 4.7ghz in real gaming mode. It's just a matter of spending the time tweaking the memory to stabilize it for each specific game and increase the water pump and fan speed to keep it in the safe temperature zone. So I will be running tests for 5, 5.3, 5.7 & 6ghz shortly. I'll share what I find over time.
P.S.>>> At 4.7ghz, I am getting 90+ frames in Mechwarrior Online. And I will be testing it for WOW & WOT when I get back to them. Right now, I'm just enjoying Mechwarrior too much!
LJM's Rig:
ANTEC 900 (modified)
CPU: AMD FX-8370 Black Edition 4.3ghz Stock O/C
Mobo: ASUS M5A99FX-PRO Rev#2
RAM: 8Gb Kingston HyperX Fury 1866mhz 2x4Gb
HDD: Seagate 1Tb Sata3
GPU: Sapphire R9 285X AMETHYST Dual -X 2Gb Vram
CPU Cooler: Corsair H80i GT(i-link)
PSU: Corsair HX1000i(i-link)
