Btw what about this one -
Corsair Hydro Series H105 Extreme Performance Liquid CPU Cooler CW-9060016-WW -
Does anybody have tested?
Ok, thank you, so I'll do some research and investigation
Johan run's his 9370 on a thermaltake 2.0 water extreme without a problem, but if you're going to really try and push on it then full custom is the way to go.
Hi Guys, thanks I suppose I will not regret
I just have to find the case, been wondering about some similar to my previous one, but this case is only for 2fan rad :/
Maybe I'll try to DIY customization with my old case first
//Edit: Guys, what abt this video? I've found some other vids abt noisy pump, somwhere has been written that it could be caused by air bubbles, so it can be fixed by shaking with the pump..
Do you have some experiences with that?
//Edit2: Seller told me, that H320 will be available abt 3-4 weeks :/ So he told me they have H220 available, I decided to buy H220, and if it will be not enough, then I'll customise it..
