QuietIce
Disabled
- May 7, 2006
- Anywhere but there
BTW: I think the only points that add to the team are the ones you make after you join. But, hey, that's OK. RAC is RAC - it all adds up ...
Yay new update. Sig rig. The 955 is a C3 stepping and yep that's right you're seeing 3.8GHz at stock CPU voltage. 2 hours Prime 95 and several hours of Crysis, Bad Company 2 and GTA4, all CPU eating games. Not a single hitch so far. Will NOT break past 3.8 though no matter what voltage I try.
Disregard the funky GPU clock was playing a bit with overdrive.
Thank you; please help some of us dispel this notion that you need X.XX volts to get Y speed. Every single CPU is a bit different though all of a particular type fall into a range. Even on the same die you may have cores with different properties.
Attachments don't resize unless you embed them in the post using the paper-clip symbol next to the smilies icon up by the text color. If you edit your post the image you uploaded should be listed in the drop-down when you click the arrow next to the paper-clip. make sure the cursor is where you want the image to be then click the attachment file name on the drop-down ...I don't know why my pic's don't resize?
Not a bad clock at all considering the load core temp you have!
