Hello there.
So I've been trying to overclock my CPU but I'm completely stuck at 3,60GHz.
I probably could run the multiplier at 18,5(around 3700GHz) but I'd like to get up to 3,80 at least.
The main problem is that I'm crashing at 3,8GHz with different Bluescreen errors. The latest one, with Bus speed at 202 and multiplier at 19 was "0x0A" which according to a guide sandy/ivy-bridge overclocking was "unstable RAM/IMC, raise QPI first, and if this doesn't work, raise Vcore"
The problem I have here though is;
1: I don't know what QPI are
2: I have no freakin clue how to raise my Vcore on my motherboard.
This is my motherboard. I'm unsure if the link works for you, but it doesn't for me(whole asus.com doesn't work - just a blank page) - if it doesn't work the name of it is M5A78L-M/USB3 AM3+
As said, my CPU are AMD Phenom II x4 965 BE.
It's nothing wrong with the temps. After 2h of stability test the max temp was 49C.
The only thing in BIOS I can find anything with "voltage" with CPU, is "CPU Over Voltage" but I haven't really got any good answers on sweclockers if this is the setting for Vcore or not.
Here's the manual for my motherboard.
Last Overclock tries I've done is via "AMD Overdrive" to check at when it crashes, and then I choosed the last "safe-spot"(x19 - 202) it didn't crash and made a stability test which after 2h crashed.
My current Core Voltage at 3600 MHz are currently at 1,464 which I think is a bit high, but then - It's the standard one for me since I haven't changed it.
If there is anything I've missed to mention, please ask and I'll answer.
I'm greatful for help.
