I would also add that you need to verify HWmonitor is showing correct temps. With two different motherboards and chips, HWmonitor has shown my core temps 10 degrees lower than they actually are.
If in doubt, find the highest temp other than your video card, and watch that temp as you load test. It should start to go up almost the moment your start stress testing.
